Question about Hobart HL600 Legacy Stand Mixer
We have no power out of the hl600 motor control board. whats wrong?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Looks like you are familiar with all those Hobart mixers. Hope you can help me too.
So I have a HL600. Got it from a school. Was working prior to remove from the school facility.
A month later plugged it in. Worked for like 20 min and stopped.
Bowl still goes up and down but there is no lights on the display.
And mixer wont start at all. Called Hobart. They sent out a tech. He checked the mixer and said all is good with it just the control panel board is bad. Ok So I got another board. Same thing. Mixer worked like 20 min and stopped. All the same sypthoms. Now since the tech said its the board thought OK. Let's put another board on it. And same thing happened again. Mixer stopped, lights disapeared.
Now we have 3 mixers and 3 bad boards I guess.
But I don't think the board is the problem anymore. What's the chance that working machine when I take out the board and put it on another unit it won't work.
The problem must be something else.
Please let me know if you have any ideas how to get them back working.
Much appreciated.
Regards Stoyan
Posted on Oct 18, 2019
    Scholar:
  • 109 Answers
Because of the very high voltage on the output of the Inverter drive, I do not want to be responsible for your injury or death from you servicing this machine without proper training.
Posted on Aug 01, 2014
6ya staff
SOURCE:
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
Aug 19, 2015 | Hobart Food Mixers
HELLO, My name is Timothy and I got a motor repaired for the Hobart H 600 stand mixer and I need to ask one Question. What is the gear oil that this model takes as I lost some of the gear oil during...
Planetary takes six ounces 150 weight gear oil if completely drained (i.e. Exxon Spartan EP 150 or equivalent). Transmission uses one gallon 460 weight (yeah, 460 weight!) gear oil (Exxon Spartan EP 460 or equivalent).
Jan 25, 2011 | Hobart HL600 Legacy Stand Mixer
Whats does b_9d mean. My mixer wont start to mix. The power is good but it tels me b_9d.
that fault is a b_gd.there are 10 things that can cause this.1.start sw.momentary contacts not closing. 2.stop sw. contacts open. 3.bowl guard sw. open or malfunction(b_gd)displayed on timer.4.contactor 1con malfunction.5.timerboard malfunction.6.wiring incorrect from sr drive to motor or 1con.7.sr drive malfunction 8.1 con monitor from control drive disconnected from contactor coil9.encoder malfunction 10.motor malfunction. hopefully just your bowl guard switch is no good. hope this helps, dont forget to vote, monomoy
Feb 01, 2010 | Hobart HL600 Legacy Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
Jan 05, 2009 | Hobart A200 Stand Mixer
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
180 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
