Let start. If Are you experiencing difficulty with Dell printer? We have a group of experts who is to help effectively execute every one of the means without agonizing over the specialized issues. Converse with the group whenever they are available 24*7 through approaching Dell Printer Customer Service Number +1-833-260-7367 and get beneficial results that can be effectively executed with no mistake. for more data go with this official site. https://www.onesearchpoint.com/dell-printer-support-phone-number
power on the printer Wait for ready mode. Press Menu -> Up -> Left -> Ok -> Right ->Cancel ->Menu
This will bring you the the Tech Menu, select it.
navigate to Data Setup (Down arrow) and press check
navigate to Clear Fuser Count and press check
Power on and off
Print a config from the reports menu to check if the fuser count 0.
keep in mind you have to press the keys (for getting tech menu) really quick, try not to look the display but the keys (the menu, up, left, ok, right, cancel, menu combination i mean) good luck
Detail It is judged that the polygon motor lock signal is not outputted. Lock signal is checked in the interval of 10sec after starting the polygon motor, and it is judged that the polygon motor does not rotate normally. Cause The LSU connector or harness in the LSU is disconnected or broken. Polygon motor trouble Check and remedy Use DIAG (SIM61-1) to check the polygon motor operation. Check connector and harness connection. Replace LSU.
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
