Sirius STILETTO 100 MP3 Player Logo
A
Anonymous Posted on Jul 31, 2014
My Sirius stiletto won't record anymore, how do I fix it?
5 Related Answers
Anonymous
  • Posted on Mar 28, 2008
SOURCE: Stiletto 10 is not reconized by My Sirius Studio
Firmware version was too old to be reconized by new version of My Sirius Studio (MSS). Put Stiletto into recovery mode, pulled the latest driver from sirius, updated, which allowed MSS to see the unit.
Anonymous
  • Posted on May 13, 2008
SOURCE: sirius stiletto volume does not work
I am having the same issue, tried all solutions listed, it appears to be a hardware issue. Going to check with Sirius, which I doubt if they have any solutions for anything.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jun 10, 2008
SOURCE: My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Anonymous
  • Posted on Nov 25, 2008
SOURCE: Sirius Stiletto II
If you’re having this problem while using the FM transmitter try using a different FM Station. I have the same problem. Mine only does this when I am using the FM transmitter. I recently noticed my volume is adjustable on certain FM Stations, and on other FM stations the volume control is limited. I hope this helps.
Anonymous
  • Posted on Dec 30, 2008
SOURCE: Sirius stiletto 100 in demo mode
All you have to do is press and hold the display button for approx 30 sec with the unit powered on. It took mine right out of demo mode.
Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
Sirius Stiletto II
2helpful
2answers
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at [email protected].
-Tha Mp3 Doctor
Stiletto only records for about 18 munutes
-Tha Mp3 Doctor
2answers
Sirius Stilleto 100 skipping issue
Usually this is a signal issue and it happens when recording indoors mostly, right? The signal dropps but only for a second or two so when you look at it its fine. you've probably notived it cutting in and out when "live" from time to time. Use your signal meter built in to the device and find the strongest signal location. If that doesnt work or its not the problem, update the software. If that doesnt work try running the recovery software but only as a last resort because you'll lose your recordings.
SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Recording
Check your settings, click on the "heart button" You should be good to go. I LOVE my stiletto 2. I've had it for a few months. Good luck.
6answers
Stiletto 100 recorded content skips
Double check your signal strength during the time of day your recording sounds like classic signal drop. Could also be software issue or memory issue. As a last resort; SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
9helpful
2answers
Stiletto constantly powering off
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
