Computers & Internet Logo
A
Anonymous Posted on Jul 31, 2014
Why my laptop unable to start up window
It hangs after window start up with "Setup is starting services". It is using window 7 home edition os.
pontelemon
Level 3:
  • Master 538 Answers
  • Posted on Aug 01, 2014
pontelemon
Master
Level 3:
Answers
538
Questions
0
Helped
175889
Points
1223
Keep pressing F8 when it boots up.
Choose "Safe mode with Networking"
5 Related Answers
rickyostrom
Ricky Ostrom
  • 274 Answers
  • Posted on Nov 19, 2008
SOURCE: i reformatted my c drive and now cant install windows
The computer should have came with a Windows Restore CD, or there may be an onscreen display telling you to press a key (i.e. F12) to boot recovery mode.
Anonymous
  • 987 Answers
  • Posted on Feb 25, 2009
SOURCE: Fn Keys not working under Vista
Please go to the following link and download required drivers
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFJ370&SelectOS=27
Anonymous
  • 13 Answers
  • Posted on May 09, 2009
SOURCE: Dell Inspiron 6000 PC Notebook
you have gone into XP's backup and restore and reset your dell to a previous point right http://technet.microsoft.com/en-us/library/bb490854.aspx ?and if it was this way the first time you booted up it might have been installed wrong and it will need to be manualy serviced unfortunately most companies don't give restore disks any more, if your dell came from a retailer and it is still under 3 month the store should reinstall xp for you and if it isn't the store still might do it, dell might also offer a mail in fix for ya, if that doesn't work you can always go to best buy's geek squad and when you get it fixed make sure to make a backup disk using windows backup and restore, vista has software to use to make a back up disk i dont know about XP
geek squad or dell might haveto do that for you but it could cost you
OneElite
  • 41 Answers
  • Posted on Jul 28, 2009
SOURCE: on startup i have multiple screens and then the computer hangs
Reinstall latest release from Microsoft.. it should solve the problem
dougmpage
  • 86 Answers
  • Posted on Jan 28, 2010
SOURCE: I have a benq joybook 5100 and xp home edition.I
When you first turn on power go into set up mode (hitting delete or F10 should say on boot up) when your in setup move to boot menu and move cd to 1rst boot order then harddrive. Pop in Xp disk and restart computer you should see "to boot from cd hit any key" hit any key and follow prompts to install xp on your computer.
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
No BIOS, can't install XP Home Edition.
Sometimes only a certain number of Windows are allowed to be installed. Ask your friend to install it for you. If he can't, don't buy.
What's your problem?acer aspire 5745 hang
Go to the website www.microsoft.com/windows/compatibility/ and download the windows 7 upgrade advisor to check the components which are not compatible and also check whether your Processor support 32 bit or 64 bit OS.If it does not support the 64 Bit Os ,the only option will be to set up the machine using 32 bit OS win7.
2helpful
I have a LG xnote rd405... I'm unable to start the
This can be fixed by Re-installing the Os into your laptop again this is due to some error files hanged in the Os program files.if your laptop if having Win 7,this can be correctly by Recovery Cd. if you like my comment please give me some points For my Better Growth,wishing your betterment
2answers
Computer not working after service pack 3 download
Depending on the setup of your computer, sp3 only worked well with a hand full of computers. Your best bet would be to uninstall service pack 3, and then buy the Windows 7 OS. To uninstall, go into your start menu->Control panel->add/remove programs-> and then search for updates installed. Scroll down until you find the Service Pack 3 update and click remove.
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
I am unable to get my desktop screen in window vista basic home e
hi,
configure your visual settings in windows classic mode including themes and wallpapers dont use side barsor any other visual effects in the run prompt type services.msc or msconfig and disable background indexing services
it can help
visit my blog http://xviruslab.blogspot.com
and download pc booster in system utilities section it clear more problems
bye bye
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
