Hot water hose leading into washer is completely clear, the input for the hot water hose on back of washer has a filter in it which seems to have some particulate matter in it. i have researched to find out how to remove but cannot find any information on how to remove such filter. Any suggetions.
Guys, i replaced the hoses, ireplaced the solenoid valve & I still have the same problem!!! NO WATER!!! What now?
The rubber of the filter stick to the hose due to time and heat of the water. Try to move "wiggle" it with your fingers to get it unstuck. Can even use the handle of a teaspoon for more leverage but try not to damage the rubber seal as it will not seal proper again when connected the tap. Clean with a nylon brush. If found impossible to remove, leave it as installed but immerse the hose end with the filter in a half cup vinegar for a hour or so to dissolved the chalk residue. Brush again with a nylon brush. Chalk remover can also be bought over the counter - same as the tuff sold to clean chalk inside electrical kettles. If every thing failed sit down with the hose end with the filter in one hand and a thin but strong/stiff piece of wire in the other hand and pry open each hole formed by the grid of the mesh.
SOURCE: Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
SOURCE: slow hot water fillup
THIS MIGHT HELP, DONT FORGET TO RATE ME THANKS
Slow-or-no-water-into-the-washer and flooding washer complaints just gotsta be in the top five most frequent appliance complaints I get. Thang about it is that it's just so gawd-awful simple to fix that I'm reluctant to give away the secret to this great cash cow. Yeah, I know, I shouldn't reveal this treasured trade secret that all appliance repair techs swear an oath to defend. What? You say you want me to tell you anydamnway? Well alright then.
Most of the time, your water flow complaints will be about either the cold or the hot water being restricted to near nothing. Sometimes, both the hot and cold water flow are restricted and the water just trickles in no matter where you got the temp control set at. Either way, 90% of the time, the problem is because of sediment built up on the inlet screen of the washer inlet valve.
Here's a typical two-solenoid inlet valve. This is the most common, although some Whirlpool's use a three solenoid arrangement, but the diagnosis and correction are the same. Most of the time, what happens is that sediment builds up on the inlet screen of the solenoid valve and restricts the water flow into the valve.
Now, here's where you can benefit from my lifetime experience as a certified technical guru. There's something I call the "cute plumber's trick" where the unsuspecting appliance owner calls in one o' them real hairy, stinky plumbers to fix their washer. Well, Buttcrack Bubba correctly takes a look at the inlet valve and figgers he's being reeeel cute by just removing the inlet screen altogether. Most of the time, Buttcrack Bubba does this 'cause he ain't even got a washer valve on his truck so it's the difference between making something off the job 'cause he "fixed" it, or making next to nothing 'cause he didn't have the part and he'd have to come back to do the repair. Buttcrack Bubba's in, what we in the trade call, "the horns of an enema." Yessir, so he goes ahead and removes that screen. The customer don't know any better; heck, all he knows is that water's flowing to his washer again. It's a freakin' miracle!
What happens next, though, is a sad tale to tell. Y'see, after a while, the innards of the valve get so gunked up with sediment that the valve can no longer stop the flow of water when it's supposed to (like, when there's no power on it). You can see here that they's a whole buncha delicate leetle ***** parts in there, da, comrade? Little, itty-***** pieces of dirt and pipe scale can stick that plunger guide wide-ace open. So, water just keeps on flowing into the washer. Meanwhile, you're outside playing with the dog, or changing a poopy diaper, or...whatever. Point is, the washer floods on you and makes one helluva mess in your house. All cause o' that "cute plumber's trick." Now, how smart was that to call in a plumber to do an appliance tech's job?
Other times, problems with no water can be the pressure switch or a burned-out solenoid in the water valve. If there ain't much sediment on the inlet screen of the water valve, you gotsta measure the continuity of the solenoid coil at the terminals. If your meter says there's no ohms in the solenoid coil, that ****** is slap-open and it's gotta be replaced. That's the name o' that tune, Hoss.
SOURCE: Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
