That's not a Sears part number. Look for a plate on the motor housing. There will be three number, a dot, and several more numbers.
Then go to https://www.searspartsdirect.com/ , enter your model number and open the parts breakdown. The manual is usually near the end of the parts list, often there's no related part number associated.
If you will find your make, model, and serial number for your refrigerator, type in "Sears Parts Direct" into your search engine, and Sears will help you find this part and will ship it to you, if this is a USA model.
With a shed load of searching of manufacturer serial numbers for every weapon they have produced and you can end up with a good few models from each manufacturer then you get pictures of each model till you get images of you weapon
Here is a bit of information that can stop the search dead in its tracks
Some manufacturers records are incomplete due to fire and other disaster's
It is because you haven't bought the game simpsons hit and run. If you have bought it from a market, check that the disk contains the serial code or not. The serial code is usually in a TXT file named Serial ID, Serial Code or Serial. If you can't find it, you should go to the market and buy original version of the game.
YOU SHOULD BE ABLE TO GO ONLINE TO SEARS PARTS DIRECT AND ENTER THE MODEL AND SERIAL NUMBER AND LOOK UNDER PARTS DIAGRAMS , I CAN'T REMEMBER IF SEARS HAS CARB PARTS BUT IF YOU LOOK ON THE ENGINE IT WAS MADE BY EITHER BRIGGS AND STRATTON OR TECHCUMSHA YOU CAN GET A PARTS BREAK DOWN FROM THEM ALSO IF YOU HAVE TROUBLE WITH THESE GIVE ME A SHOUT WITH THE MODEL AND SERIAL AND I'LL FIND THEM FOR YOU
