Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Testimonial: "Hey Knight Thanks for the info. I think I am on right track now. I ordered a main board Pcb,bal bd PART NUMBER: A1763462A. Will try and replace this and go from there."
It sounds like the main board
SOURCE: PROBLEM EITH SONY TV KDF-E55A20
We had the same thing happen, it was the thermal fuse and cost us 400 to replace now it has been 6 mos. later and having the same problem. The part is only 22.00 but I am not sure I can replace it myself without messing up something else.
SOURCE: sony bravia screen doesn't work but sound still
Ur Video converter board is dead,need a new one.
SOURCE: Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
