Remove the cylinder heads and de-carbon the heads and top of the pistons. Hot spots of heated carbon buildup are igniting the fuel after the key is off. Install new spark plugs > NGK B8HS. This will fix the continued running problem.
The out of control revs is an air leak problem. Un-carbureted air is making the fuel/air mixure lean. The hose clamp at the front of the carbs may be loose and/or the gaskets from the reeds to the cylinder are no longer keeping a good seal. The carb joints and reed gaskets should be replaced. The gaskets are cheap. The carb joints are expensive. Considering this, you may want to put some gasket sealer on the carb joint mating surfaces and see if they will seal up okay. If the carb joints are cracked, you pretty much have to replace them. Please rate my answer, thanks.
