Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
SOURCE: 2004 Buick Rendezvous AWD Light Stays On
Our 2002 did the same thing. Easy cheap fix! Pull the wheel off and check the wiring that goes to the wheel sensor. You will find after removing a few inches of wrap, a broken wire or two. This could be on either wheel, so check both. Fix the wires back up and you are good to go. Hope this helps!
SOURCE: Can my 2005 Buick Rendezvous be towed by a motor home
If it has an automatic transmission it isnt the best thing to do.The transmission pump wont suply lube to parts that need it and stand a real good chace of causeing damage due to the lack of lubrication.
SOURCE: 04 buick rendezvous drain tube holes
run a piece of wire down them, rebar works well for this
SOURCE: What are the steps to replacing a driver's side
You need to remove inner door panal so you can get to screws and unplug electric mirror adjustment wiring harness. replace using reverse procedres.Good luck.
SOURCE: My 2005 buick rendezvous keeps
most likely caused by a short, could be any were. start with the light assembleys remove it and clean any rusty or coroded spotspull all bulbs clean and or replace .auto parts stores sell an electrical parts wash about 9 to 14 $ . spray as needed let dry and put back together.if it still blows fuses its some ware in the wire s , could also be at the turn signal switch or the brake switch . you would have to get it to blow to figure out witch one it is and witch one it is not example put in new fuse then keep putting on the brakes if not blown then keep doin the turn signal then check to see if blown
