My record player is fluctuating in speed and then slowing down and it makes all my records sound terrible.
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
SOURCE: sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
