Need to check the insulation at the supply line into mr slim inverter unit, need to know how to open the bottom panel, please?
SOURCE: Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
SOURCE: MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
