SOURCE: Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
SOURCE: presario f700 no fan/lights = nothing at all. The charger works
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
SOURCE: tell me which motherboard is in my compaq presario
Download PC Wizzard, ( it is free) Install, Here you will find all the info you need involving, Hardware performance, hardware specs, Good luck. I did do a search and found that the f700 has a Mobile AMD Sempron™ Processor 3600+ but no seprate mention on motherboard.
SOURCE: Compaq Presario F700 DVD problem. Today would not
Please perform the below steps to fix this issue.
1. Check in device manager for cd drive option. in case its visible, right click on it and uninstall it and reboot the system and the corect drivers should get loaded automatically.
(to go to device manager follow the below steps:
in XP---1.On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
2.In the System Properties window click the Hardware tab.
3.In the Hardware tab click the Device Manager button.
in vista\windows 7---1.Click on the Start Orb.
2.In the Start Search box type: device manager and then press enter.)
2. Delete the upper and lower filters:
For XP
Start -> Run ->regedit - > Ok
It opens the registry editor window. navigate as per the below path
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the right side pane if you see upper or lower filter options...right click and delete them.Restart the system
For Vista
Start - > Search - > regedit - > OK
3. Check in Sysem setup/BIOS and see it the drive is getting detected. in case the drive is not getting detected over there it is a possibility that the data cable that connects the drive to the main board might be loose. if that is the case we need to go into more detailed troubleshooting. please let me know if above steps fix the issue else will provide further steps.
regards.
SOURCE: Compaq Presario F700 motherboard? is it
download free CPU-Z / install / run and it will give all PC info
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
