I have pulled out the filter and cleaned it but the machine has the light on for "clean filter" and the humidity setting is continually at 50-60.
Hey friend, thank you for the post!
I understand that your dehumidifier continuously is set at 50-60 and the clean filter light has not stopped. I would like to ask you some additional questions in order to provide you better assistance. First, does the appliance still collect water? Secondly, have you tried to reset the appliance? I look forward to your comment back so that I can further help you. -Matt
SOURCE: I have a 2 year
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
