I only have this ac less than 4 months old is it normal to see dark rusty particles while draining unit? or is something wrong with it.
SOURCE: Amana Prestige II -- breaks down every once or twice a year.
cap is worth about 16 dollars the surface ignitor around 40 there is a ball style that can be moded sometimes with a kit . the wafer type are prone to breakage if there is a lot of vibration in the house or possibly your furnace blower cage is bad.around 60 for that. i think your getting taken
SOURCE: Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
SOURCE: Manual for Amana AP076E portable a/c
The manual is by Haier but you will see it is or the Amana AP76E. - http://service.haieramerica.com/documents/User%20Manual%20AP076E.pdf
Testimonial: "Great job!!"
