Question about Pentax IQZoom 200 35mm Point and Shoot Camera
Problems with camera. Help please.
This happened suddenly, after I had shot nearly 2/3rds of a roll.
The camera zoomed out completely and when switched off, retracted only half. Pressing the zoom control helps - the zoom retracts and the flash moves inside the body. But when the camera is switched on again, the same thing happens - the whole zoom comes out and does not retract. The indicated on the panel indicates U7 (flashing). The shutter button does nothing. Please help.
I am based in New Delhi, India. Is there a Pentax Service Store over here?
My email address is as_kanth@yahoo.com
Thanks a lot.
Srikanth
  • Milli35772 Apr 17, 2008
    I have a Pentax IQZoom 200, my camera is doing the same thing withthe zoom lens. Is this a common problem with these camera's? I am really saddened by this. How is it fixed? The zoom comes out when the camera is turned on and then only retracks part of the way. Error code U7???? Nothing in book about U7?? Please help!
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Posted on Nov 19, 2007
6ya staff
SOURCE:
When i turn on camera zoom canot work properly then requied returning on camera
link
Try above link for better understand of your camera. And if the camera continue to experience technical problem, better to consult your Sony Help Desk near your are.
Thank you
Jul 30, 2010 | Sony Cyber-Shot DSC-P10 Digital Camera
My camera shuts off when I my zoom is nearly halfway through
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
Sep 27, 2009 | Kodak EasyShare V1073 Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
:( please help - lens problem
time for a replacement camera...as the repair wouldn't be to expensive to consider.  Use your wrist strap
Apr 01, 2009 | Casio Exilim EX-Z30 Digital Camera
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Turn the power off and on again
turn on
gently hold end of lense and twist and pull gently you may hear a click dont force it
turn on and off again and this should solve problem
Sep 07, 2008 | Sony Cyber-shot DSC-W170 Digital Camera
Help!! 10-year old Accura Zoom 80 film camera is taking blurry photos all of a sudden
you should be able to place your hand in front of the auto focus window while looking in front of camera (be careful not to blind yourself with the flash) you should notice the lens moving sightly as if to focus. The best way though is to actually shoot a roll through it. Do not shoot a wedding or anything of real importance...the cost of a roll of film and develop is worth piece of mind.
Jul 04, 2007 | Olympus Accura Zoom 80 35mm Point and...
Button for exposure
Nothing to fix - this is a major switch problem Contact Nikon technical support team for advice but I fear it is new camera time
Jun 22, 2007 | Nikon Coolpix 5700 Digital Camera
G-2 Power Shot no longer closes completely
I had the same problem with my G1 and it seems that with time and with usage of the cam it ends up doing this, i solved my problem moving it back and forth but slowly and then try to push it softly ..then turn it of and on ..and it will go in.., suddenly it will happen the same thing again and again.. because mine still does that some times
Apr 02, 2007 | Canon PowerShot G2 Digital Camera
Pentax IQZoom 200 35mm Point and Shoot Camera Logo
144 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
