Question about Black & Decker DF200 FryMate Fryer
Is there a Black & Decker USA ZG20A-12U-502 detachable cord available anywhere?
Can an alternate power cord from some other piece of equipment be used?
    Master:
  • 428 Answers
Go to your local part store to find won for ya and ask him repair stores too will help ya too
Posted on Jul 29, 2014
6ya staff
SOURCE:
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
Where can I get a electric motor p/n 90520850
250 MPH Electric Blower Vac Mulcher ' BV5600 ' BLACK+ ...
www.blackanddecker.com/.../blower...blowervacuummu...
Black & DeckerThe High Performance 12 amp motor 3-in-1 blower, vacuum, and mulcher keeps ....blower I was using and I let him use it and he liked it alot said he'd never buy the ... So thanks again Black & Decker for making a safe usable product that will ...
Black and Decker BV3600 12 Amp Blower Vac - Amazon.com
www.amazon.com > ... > Leaf Blowers & Vacuums
Amazon.com, Inc. Rating: 4 - ‎138 reviews
Greenworks 24012 7 Amp Single Speed Electric 160 MPH Blower B0030BG1CC ...The Black & Decker BV3600 Blower Vac has a powerful 12 amp motor. .... really well, so that I had about 4 bags of debris to empty, and I have a big lawn.
Oct 23, 2015 | Black and Decker USA Black & Decker...
1 year old starting spitting out possible cord pieces and hitting me in shin area. at first I thought it was little rocks or pebbles,,but not
The cord is not properly wound on the center spool, or there is dirt, grass, plant parts, etc. in the spool release mechanism.
First step clean and check the spool and release.
Jul 27, 2015 | Black and Decker USA Black & Decker 12"...
I have a 350 amp Black & Decker jump starter model JUS350B.Why can i not get power across the clamps with a test light
First: the Jump-Starter power switch must be in the "On" poistion, or no voltage will be delivered to the clamps to light your test light.
Second: from the Black & Decker JUS350B owners manual (http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90553956,JUS350B.pdf?_ga=1.9223413.1518759147.1438019791)
This product has a sealed lead acid battery. For maximum battery life, we recommend the Jump-Starter be kept
fully charged at all times. Recharge before first use, immediately after each use, and once a month if not used.
Failure to do this may reduce the battery life dramatically. To check the battery charge status at any time, press
the Battery Charge Level Pushbutton.
When the battery is overly discharged and if the green LED is lit when the charger is plugged in, this indicates the
battery is at a high impedance stage.
In this event, recharge the unit and leave the unit on charge for a period of 24-48hrs before using the unit.
Also, the product reviews by consumers about this (made in China) product are abysmal:
http://www.blackanddecker.com/en-us/product-repository/products/2015/02/01/01/15/jus350b
Jul 27, 2015 | JUS350B 350 Amp Jump Starter
One of my beaters broke. How can I go about getting a replacement pair? MX55 Power Pro 200 watts Black and Decker hand mixer
For some reason, although you can find this mixer offered for sale, there is no information available for it on the Black & Decker websites in the USA or Canada.
I did find one mixer on the official Black & Decker parts site, which may be similar, with replacement beaters available as Part No. 177177-00 at $12.95 a set:
http://www.foxsales.ca/accessories.asp?modelnumber=1196
Your best option may be to use the Black & Decker Service Center locator to locate your nearest sevice center. This is a part they normally would stock and a quick telephone call should be able to determine availabilty and price.
http://www.blackanddecker.com/Service-Centers.aspx
Feb 06, 2011 | Black & Decker MX55 PowerPro Hand Mixer
I have a Black and Decker Frymate but no cord. I haven't been able to find one on eBay or other net sources. Help! Thanks, Victoria
You did not specify your model number. Replacement parts for the Black & Decker DF450, including power cords are available here:
http://useandcaremanuals.com/pdf/DF450C.pdf
If this is not your model suggest you call thihs supplier at 800-738-0245 to determine whether this cord is compatible with your model.
Dec 26, 2010 | Black & Decker Kitchen Appliances - Others
Instruction manual for Black & Decker deluxe router guide # 76-234
There is no manual for this piece of equipment available through Black and Decker. I will link all the literature available for it. I'm sorry.
http://servicenet.dewalt.com/Products/Detail?productNumber=76-234
I hope this helps.
Dec 05, 2010 | Garden
Need a recharger cord for my Vector VEC270S, Can't find anyone locally in Memphis who carries parts
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
The Vector VEC270S has a built in charger and can be recharged by connecting it to a extension cord.
Oct 01, 2010 | Vector 1 Million Power Series Spotlight &...
Cord is rapidly "minced" up
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
Jul 09, 2009 | Black & Decker String Trimmer Cordless 12"...
What power supply to use
The black& deck doesn't go with either one,
The Sb5120 uses a standard cord(no transformer)
The LinkSyS uses the LEI 12V power supply.
May 10, 2009 | Computers & Internet
Black & Decker DF200 FryMate Fryer Logo
134 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
