It slips--like the bobbin pin is not grabbing the bobbin. It used to work.
SOURCE: bobbin wont spin
I had the same problem last night but was able to solved it by flipping the plastic bobbin over and re-seating it on the post. This time it clicked in and I was then able to get the post to spin. Good Luck!
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
SOURCE: I have a Janome Memory Craft 4800 Quilter's
Your sewing machine needs to be taken into an authorized dealer for service.
