RIM BlackBerry Curve 8520 Smartphone Logo
J
Julie Webster Posted on Jul 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What can I do ....myblackberry curve charges and light turns green but the screen does not come on
RONALD CARTER JR
Level 3:
  • Master 438 Answers
  • Posted on Jul 29, 2014
RONALD CARTER JR
Master
Level 3:
Answers
438
Questions
0
Helped
91543
Points
1345
Hello Julie Webster it sounds like the phone is not charging. Plug your phone into your desktop manager for Blackberry if you have it. You want to save your information as soon as possible. If your curve still does not come on when it is plug into your computer then the charging port is either dirty or not working at all. The curve had an issue with it\'s charging ports. If is a Verizon phone the may be able to replace it. If this is not an option here are a few steps for you.
You need a stiff but clean toothbrush and can air. Take the brush and clean the dust and dirt out of the charging port. Do not blow into the charging port to long because when the can starts to feel cold you spraying to long. One more test to see if your charging port is actually charging. See if the charging port moves with the plug inside it. Don\'t be to hard on the port it can become lose very easily.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
1 Related Answer
Anonymous
  • 116 Answers
  • Posted on Sep 26, 2011
SOURCE: can anyone give me an nlock code for myblackberry
Don't worry about it. it is very simple to Unlock your Blackberry 8520 by entering Imei Unlock Code . you can get your Mep Unlock Code for Blackberry 8520 by third party or your network provider.third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy Blackberry Imei Unlock Code from third party. they will charge little amount.i hope this will help you.
Green led light stays on,there is no messages or missed calls
I think it's there to tell you that you're within network coverage.
You can turn it off by going to Options, Screen/Keyboard, and set 'LED Coverage Indicator:' to "Off".
Hope this helps!
Myblackberry has error message 513 reset on it. how do i fix it
Your Blackberry probably needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings. Download the Blackberry Desktop manager and run the application loader.
2helpful
2answers
Been on charge all night. wont turn on and has rotating black clock in centre of a blank screen
my blackberry curve went dead and when i placed it to charge for the entire night i tried to turn on the phone and it wont turn on but there is a red light on the phone for a few minutes .... what can i do?
Replacement batteries don't charge after only 3 charges green light after charge, but only travels 10 feet and stops turn off key, and it does the same thing
That really sounds like the batteries need replacing but first check the battery connections.
Are you sure the battery charger is working correctly ?, can you try another charger ?
Regards
GeWiz.
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
1helpful
Yellowish green hump/curve at bottom of screen. Blue is at fault
Easy one of the two convergance chips
has failed .they cost about 10-30$ etch
so dont let them over charge you ,if
you decide to get it repaired
2helpful
3answers
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
