I don't know how to set the time....all of the rest of the information shows up in a few second. The batteries have been changed.
You're not supposed to set the time -- it's supposed to synchronize with the US atomic clock broadcast automatically. Perhaps putting it in a different area of the house, or turning it to a different orientation will help it make the initial connection.
If it still won't, here are instructions from one of the LaCrosse models... use them or go to http://www.lacrossetechnology.com/clocks/atomic-digital/wall/
and find your particular clock, then download the instructions.
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock. Note: In 12 hours mode the time will be displayed with an additional "PM" for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1.
2. Set the desired hours by pressing and releasing the + key followed by pressing the SET key.
3. Now the minute digits will start flashing.
4. Set the desired minutes by pressing and releasing the + key . If the + key is held, the units will increase by 5.
5. Press and release the SET key to move to the "Year Setting".
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the next hour.
WWVB reception occurs daily at 12:00 am and 06:00 am. If the reception is not successful at 12:00 am, then the next reception takes place the next hour and so on until 06:00am, or until the reception is successful. If the reception is not successful at 06:00 am, then the next attempt will take place the next day at 12:00 am.
The other times WWVB reception takes place are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
