Need to get device to boot to the jump drive
Restart your PC by pressing the f10 or f9 key many times as it boots.then change boot order and restart PC.
Turn the computer off in the normal way.
Turn the computer on, tapping the F2 key [it might not be F2, could be esc, F1 F8 or F10, depends on the make and specific model of your PC, for my HP desktops it's F2] a few times each second. This should enable you to enter the BIOS set-up (which key to press) (see https://answers.yahoo.com/question/index;_ylt=A0LEV2bavtZTVmcAjVFLBQx.;_ylu=X3oDMTE0bTVyc3Q3BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkA1ZJUFVLMDdfMQ--?qid=20071012195523AAXHNK3)
Look at he screen carefully while you do this, because the computer often tells you how to enter the BIOS setup during the start-up process, but the information isn't the for very long: you may have noticed this while you starting the computer all those times in the past.
Once in the BIOS set-up navigate to BOOT options or something like that. You may have to work your way every option (there aren't that many) to find it. Once there it will show a list of places to boot from - these are typically the hard drive, the optical disk drive, and the USB port, you may even have eSATA option. These will be in order. Change the order to make the laptop try to boot from a USB device first. Now exit the BIOS set-up saving the change to the boot device order. If there isn't a USB device when you next boot the laptop will just try the second device on the list. If you start up the computer with a bootable USB device in a USB port, it will boot from that device. (eg a flash memory drive)
There are other ways, but this is fundamental way if your BIOS supports boot from USB (my desk tops do not so I had to find another way)
28.July.2014
SOURCE: i can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
SOURCE: I have an HP 110 Mini
either your hard drive has been damaged or it has been disabled by the bios. Your netbook probably has a solid state hard drive. You need to get your information removed from the drive at this point and get the operating system of your choice installed. For further assistance, you can call us 24/7 at 800-595-3564.
SOURCE: HP G5000 (G6010EM) DVD Drive fault
HI HAD THE SAME PROB TAKE OUT DRIVE PUT A DIFFENT ONE IN LET INSTALL IT THEN BOOT DOWN PUT THE OLD ONE IN IT DID FOR ME HOPE IT HELPS DAN
SOURCE: I can't seem to get
Start up the computer and hit F10 a few times during start-up and login to the BIOS and check that the USB drive precedes the hard disk and CD/DVD drives in the boot order. Use the + and - keys to move the boot devices up or down within the boot order. After you have completed this, hit the ESC key and then choose Select Save Changes and Exit. The computer will now attempt to boot from the devices in the order you have specified.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
SOURCE: how to boot hp nx9010
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
