The litter box quit working. I have heard that there is a way to manually reset it. Has something to do with some sort of box or switch?
I HAVE A LITTER MAID AUTOMATIC LITTER BOX AND THE FRONT CENCER QUIT WORKING I HAD TO BY HAND WITH MACHINE ON PULL IT BACK INTO POSITION IT TOOK A WHILE BUT GOT IT TO GO BACK THEN LEFT IT THERE & NOW SCOOPING OUT LITTER BY HAND UNTIL I CAN FIND ANOTHER CENCER. I HAVE NEVER SEEN ANY TYPE OF RESET BUTTON ON IT. YOUR CENCERS BOTH FRONT & BACK MAY BE DIRTY TRY CLEANING THEM GENTLY WITH A Q TIP & RUBBING ALCOHOL.
SOURCE: xNon functioning littermaid LM980 mega
Common problem with Littermaid boxes. Try a better brand of clumping litter. Try using a little less litter. And you can help the rake lift up by slowly pushing on it with something, giving it more strength. I had this problem and found that if I "helped" the rake return to its normal position, it would work most of the time, and then need "help" every once in awhile. I actually gave up on littermaid type boxes...they just don't work very well.
Self-cleaning litter boxes are increasing in popularity and
are available at most local pet supply stores in your area or online. Here are a few places for you to search and
compare.
http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
