I've put a family code for my littel brother xbox, now i forgot it what to do to reset it, i tried evry trick in the book, but it doesn't work. my serial number is 022719723243 and it's dashboard 2.0.165370.0.
Follow this youtube video... Removing password for family settings Xbox 360 NEW Dashboard 2 0 16537...
Your manual that came with it should show you how to reset it ok
SOURCE: xbox 360 family timer
Try Unplugging it for an hour or so (like how power outages ask you to set up your console) and ask him if he knows it...
or de attaching the HDD :) it's removable you know!
so much power for a little kid :(
SOURCE: xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
SOURCE: Cannot remember my Xbox 360's passcode and reset answer!
Try these steps first:
Go into settings
.... console settings...then device settings or the
blue screen then go...
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
x
If that doesn't work then call 1-800-4MYXBOX they will walk you through it.
SOURCE: Forgot password to unlock family settings on xbox 360?
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings
Console settings
Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
SOURCE: i forgot my family passcode
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to
control access to features and options. Because Family Settings exist
for both the console and for Xbox LIVE accounts, you can set pass codes
for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When
you set an Xbox LIVE pass code for your profile, anyone who wants to
use that profile will need to enter the pass code before signing in to
Xbox LIVE.
To set an Xbox LIVE pass code:
To reset your pass code, repeat this procedure at any time. (You
will have to enter your original Xbox LIVE pass code before you can
create a new one.)
Set a Family Settings Pass Code
When
you create a Family Settings pass code, anyone who wants to change
family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game
and movie settings if you (or those with whom you share your pass code)
want to play games or watch DVD movies that your console settings
normally block.
For example, you could give the pass code to your 18-year-old so
that she can watch R-rated movies that your younger child is not allowed
to see.
To set a pass code for your console:
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX
(1-800-469-9269).
