How to connect bose to new Samsong smart tv
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
SOURCE: Connect my remote of my bose lifestyle 18 to my samsung 46a 650
Hi, have you tried going to the system settings menu adn program your 3rd party products htrough there? You may try varied IR code settings for your electronics from there and one of those codes should work atleast for your system. There may be some codes you will get to use but does not have all the funcitons so you need to be patient to try them all.
As per the Blue-Ray DVD, the remote code might still not be embedded on the IR controller chip that is installed in your Lifesytle (after you have tried all the codes and still none works). Bose does release regular firmware updates via their user mailer (if you have registered your product online) or you may passby any of the Bose service center and request them to provide you with the update disc specific to your system version (look underneath the DVD player and the bass module they should indicate AV-- and PS-- models).
Glad to be of service...
SOURCE: Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
SOURCE: Connecting ipod to Bose lifestyle 48
I have a Lifestyle 48 and called Bose today. It is possible all you need is a cord that is a 35mm headphone jack on one side and RCA jacks on the other. You plug it into the AUX jack in the back of your system and the headphone jack in the Ipod headphone spot. I got the cord at Best Buy for ten bucks. It works GREAT!
