If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: commtel control freak 4in1 remote
have a 4 control freak uni remote lost booklet would like to down load one pls also have u code for remote media windows pc
SOURCE: Trying to put volume onto Sky remote handset from
Well you can please follow the below link to get you code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Thanks for using FixYa!!
Good Luck!!
SOURCE: I have ATT u-verse remote, but I don't have code
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are:
1004 and 1018
try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions:
*Turn on your TV first
1)Hold the TV button on the AT&T remote
2)While holding, hold the OK button
3)Now release both of them
4)All the mode buttons while now flash twice
(You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over)
5)Now, quickly, type in the combination (in this case, 1004, or 1018)
6)The TV button will flash 3 times if it works, or a long flash if it doesn't
7)Now point the remote to the TV and press Power. If it turns off, IT WORKED!
*Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
SOURCE: I need the 4 digit
AT&T don't list any codes for Hannspree, but I have it on good authority that either code 1004 or 1018 work for Hannspree. Others have reported that the some of the codes for Vizio TVs will also work. There are: 1489, 1429, 1433, 1439
If none of these codes work, please let me know and I'll try to find some alternatives. It would help if you could let me know the model number of your TV to narrow my search.
I'd also be grateful if you could let me know which, if any, of the above codes worked for future reference.
Regards,
BElectric
