Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
SOURCE: Soap dispenser drip
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
SOURCE: soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
( ) indicates recommended quantity
Valve assy, inlet
SOURCE: Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
