this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
You are likely experiencing this error because of an error with the java files that are on your computer. You see, some part of the java installation is corrupted when you receive this type of error. Java controls all aspects of MP3 Rocket's functions, even starting up. When Java is corrupted, it appears that MP3 Rocket is broken when really it may not be. You cannot physically inspect Java to be sure it installed properly so you must first do an uninstall, a restart, and then the Java installation followed by the Rocket installation. This should correct your problem. Tom Miller KD4DTK
Jar file requires no installation.. Just copy the Jar file into your device, run it from your device and it will start working if Jar file is not corrupt.
sounds like this would be a java-script error. you can try re-install java-script http://www.java.com/en/download/ it might be a good idea before you re-install, to uninstall any instance of java from the control panel - add/remove programs, or programs and features section for vista/windows 7
the error refers to a missing mp3rocket.jar file within the installation of mp3 rocket. i.e. C:\program files\mp3 rocket\lib. solution is: uninstall mp3 rocket and uninstall all versions of java and JRE from add and remove programs(XP) then restart. install a new version mp3 rocket and you will be prompted to download java again. once installed MP3 Rocket.exe should be restored
1.Open Default Programs by clicking the Start button, and then clicking Default Programs. 2.On choose the programs that windows uses by default, Select “Associate a file type or protocol with a program > Click on the extension (.jar) to view the program that opens it by default. 3. Click change the program and select the default program JAVA virtual machine launcher 4.Click close. Change-which-programs-Windows-uses-by-default http://windows.microsoft.com/en-US/windows-vista/Change-which-programs-Windows-uses-by-default Now check if the issue is resolved If the issue persists, you may want to uninstall and reinstall JAVA. How do I uninstall Java on my Windows computer? http://www.java.com/en/download/help/uninstall_java.xml How do I manually download and install Java for my Windows computer? http://java.com/en/download/help/windows_manual_download.xml If the issue still persists, you may want to check with MP3 rocket for any known issues http://www.mp3rocket.com/support/
