SOURCE: Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
SOURCE: Technics/Panasonic Sa-Da 10 A/V reciever
Those 'black bars' are the integrated preamp/output stages. This has benefits from a production standpoint and even from a quality standpoint since these modules have all the necessary feedback internal to them so using them, one can expect consistent performance without a a bunch of tweaking at the end of production.
If you would post any nomenclature you can uncover on the exposed side, one of us will be able to source them and they have typically not been that hard to find or expensive to purchase.
They are made by a number of different semi houses like National Semiconductor, Texas Instruments, Maxim and several asian houses particularly from Taiwan.
The highest power module I've had to deal with was 40+40 watts but I don't recall the PN or maker.
They do die, but often, if you can extract the PN from them, you can find schematics of the innards from the manufacturer on line and use them for troubleshooting. Once you've seen the diagram, they are not all that exotic.
PNs typically start with letters and end with numbers such as TDA 1657. Four digit numbers most often are the approximate date of manufacture; 3804 = 38th week of 2004.
SOURCE: no left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
