Water leaks out bottom and doesn't go through t-disc
SOURCE: leaking from the bottom
Check the peircing nozzle to make sure there are no small bits of foil from the disks in there. Descale the machine according to instructions in manual AND most useful for stopping the leaking was cleaning the little overflow nozzle located when you remove the cup stand/drip tray, followed by the splashback. The nozzle is located at the top of the little recess/indent. Clean with vinegar. Re assemble and test. Good luck.
SOURCE: hi, i turned on
I suspect the same thing happened to your Tassimo as happened to my friend's two previous machines! Fortunately I think I found the problem and it's easily fixable! Checkout http://www.stuartdalby.co.uk/miscellaneous/tassimo_repair/index.php
Stuart
