Samsung SYNC SGH-A707 Cellular Phone Logo
A
Anonymous Posted on Jul 26, 2014
Samsung A707 key pad light how to make it stay on when fliped on
1helpful
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Microwave turntable works intermittenly - also no light
if you have on the key pad turn table on/off it may be the pad itself / I would ck the connections on the prosser . as the get film (correded ) you can use a spray cleanner for this . and it may correct the problem . flickering light may be the element and it may fail . (soon ) ****
6helpful
Screen fliped upside down
Hi there.
Hold down Ctrl and Alt and use the cursor keys (arrow keys) to flip the screen the right way up, usually the cursor up key will do it.
Good luck and thanks for choosing FixYa!!
HOW DO YOU PUT A MicroSD CARD INTO A SAMSUNG SGH-A707
If you hold your phone with the front lcd facing you (don't flip it open), on the right side of the phone there's a media player/profiles button/key, above that is the cover for the MicroSD slot.
See this link to the SAMSUNG support page: http://downloadcenter.samsung.com/content/UM/200708/20070822040959265_att_a707_sync_ug.pdf
Cell phone key volume
Go into settings and search somewhere either for Main Menu settings or for Sound Settings. If you cannot find it then, just open every setting and read them. You will find it. Hope I Helped!
2answers
My problam is unloke samsung a707
To unlock samsung sgh-a707 type this code on normal dial screen #7465625*2877#
How to change tone when getting a text message on a samsung A707
1.Go to options then set profiles.
2.Click on normal and hit the right key.
3. Go down one and select change.
4. Pick your favorite ringtone!
Samsung SYNC-A707 AT&T Cellular
Either the battery cover or the back housing is damaged. To fix it and fix it right, you need to replace the damaged part.
Look online, or check out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited.
Other than that, the only other option would be to tape it on.
Samsung A707
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!!
But you can try following steps to get rid of it:
1. Takeout the battery of your phone.
2. Leave your cell in air for a day or two without attaching battery and battery cover to it.
3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
