Power light is flashing
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
SOURCE: No Power
This is a very common problem. Theres a guy on ebay that will fix it for you for 24 bucks plus 5 bucks shipping. When you open the monitor, on the back panel there are 2 boards. One is a power supply board, the other is the interlogic board. The power supply board is where the problem is. I do not know the exact component that needs replacing as I did not test this yet. I do not have the proper test equipment. For 24 bucks, I'm just gonna let the ebay guy repair it. I will report my results here when I get the board back. I'm also gonna mark the components so I know what they replaced.
SOURCE: Acer Monitor 1706
I replaced the 470uf 25v capicitors and this fixed the problem. I had 2 monitors exactly same with the same problem and it fixed both of them.
SOURCE: Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
SOURCE: I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
