Question about Wharfedale LP160DTRHDMI
How do you restore your wharfdale tv recorder to factory settings?
Sometimes it freezes other times it records programs i havent set. Its just generally messed up so i want to try a system restore to factory settings before i buy a new one
6ya staff
SOURCE:
Lashawn Robinson
  • 1153 Answers
SOURCE: wharfdale DVDRHD400 dvd recorder with 80gb hard drive
Sounds like if you are getting the right Video and not audio then the audio are hooked in wrong. Unless you are on SAP (Second audio program) in this case take it off of Sap. If you are getting the sound that you are looking at once you change channels to view another program, then it should be easy. Just change audio jacks back to AV1, 2, 3 etc depending on which one you are using. Hope this helps!
Posted on Dec 03, 2007
Anonymous
  • 47 Answers
SOURCE: Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Posted on Jan 13, 2008
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: wharfdale dvd recorder
Turn on,
Open tray,
Press 3597 on the remote,
Use arrow buttons to select code 9 from this menu
Press enter,
Press menu and player will be region free.
this is from forum u didnt specify model number but this is the closes i came to your model if this is it
the forum stated this your players name code
Posted on May 26, 2008
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: DVDRHD400F tuner has no sound.
First of all check all your audio connections make sure the output o of the receiver goes to the input of your tv.
Keep me posted.
Thanks,
Lee
Posted on Jul 19, 2008
Chris Jowsey
  • 208 Answers
SOURCE: i have a wharfdale dvdr24hd and can't get it tuned
Use AV Leads to connect to set top box
Posted on Mar 18, 2010
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
My thomson DTI6300 digital TV recorder shows that it is recording but does not stop at the required time. No recording is actually made and the message comes up ''recording failed''. This happens whatever...
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Jan 22, 2010 | Televison & Video
DVD/HDD machine freezes and needs to be reset each time it's used
yes there is .......u can reset to factory setting.....u will find it in ur Manuel booklet/////
if not go in touch with daewoo service depaartment and u will get help from them
cheers hope all works out for u.......
Jul 03, 2009 | Daewoo DVG-8500N DVD Player
Intermittent Recording
in you menu change your video format , check all settings,what type disc are you using ? are you recording to hd or to dvd, ? check your
firmware update
still have problems call 0403960527 jeff
email jcshepard55@hotmail.com
Feb 16, 2009 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Wharfdale TU320DTR channel settings
check the menu of your remote thin find the channel setings
Dec 30, 2008 | Televison & Video
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Oct 07, 2008 | Televison & Video
Wharfedale LP160DTRHDMI Logo
60 people viewed this question
Top Wharfedale Televison & Video Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
