The tv does't change channels except when you press the exact numbers of the channel and dosen't receive higher numbered channels
Www.retrevo.com/
Try this link. Gopakumar Gopalan Google
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Doesn't sound like a remote issue as much as an internal programming
problem. If you block a channel due to a bad signal on antenna
mode, it'll skip it unless you drop the block. The same happens with
"autoprogramming" for cable. Bad channels are blocked due to weak
signal.
Maybe you should try auto programming through the TV's initial set-up
menu? You can get your television to reset to factory settings by
1. turn the tv on
2. hold down the reset button on the remote
3. press the power button on tv (tv will turn off and on)
4. release the reset button.
5. should be in initial set-up.
SOURCE: channel number in corner
If you have the original remote control, press "display" to get rid off it.
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
SOURCE: how do i stop the tv from constantly displaying channel number
Press the "display" button on the remote.
