To be honest the
best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to
restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis
less , then pull it up gently with your fingers.
Also there are machines these dayswhich have
easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it
pullit up and it would be fine.
An example of a
manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsPHope this helps ..:)
