Keurig Elite B40 Coffee Maker Logo
A
Anonymous Posted on Jul 26, 2014
Keurig troubleshooting will produce small cup of coffee only
5 Related Answers
Anonymous
  • Posted on Jun 14, 2009
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Anonymous
  • 28 Answers
  • Posted on Feb 07, 2010
SOURCE: keurig coffee maker does not make a full cup,
Check the needle to make sure it's not clogged. You can completely remove the k-cup holder and wash it out with your kitchen sink sprayer to help remove any obstructions. The manufacturer even recommends using the tip of a small paper clip to help push out any debris if needed. Then try brewing a cup of just water on the largest setting without a k-cup in it. Hope that helps! Best of luck...
cmccune04
Clayton McCune
  • 214 Answers
  • Posted on Apr 13, 2010
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Anonymous
  • Posted on Jul 09, 2010
SOURCE: when i put the coffee cup in the keurig....nothing
use a small needle, paper clip or pipe cleaner and run it up into the "needle" section under the lid that pierces the top of the cup. The problem is one you will have often as coffee grounds get up in there and dry between uses and clogs the hole.
jimmy phlow
  • 3 Answers
  • Posted on Aug 05, 2010
SOURCE: Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
2answers
Contact Keurig customer service They will walk you through some trouble shooting and advise you what to do. They replaced mine completely as these are basically made to be disposable.
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Machine only responds to large size, but then produces less than small amount. Often does not respond at all.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Prime light on three brew lights on pressing cup produces no coffee
heatman101
Does not produce full cup of coffee, only fills cup about 1/4 when full setting selected
heatman101
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
In need of operation manual for Keurig Model #830
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
