I am guessing you are saying it requires two cycles to dry a normal sized load. If that is the case, the answer to your question is No, but only if you have chosen the proper selections for the type of load you are drying on the control panel. Heavy loads require longer dry times and a higher temperature setting. Lighter loads/items will require the opposite. Is your washing machine spinning fast enough to remove the amount of water it is supposed to? You may have a problem with that instead of the dryer. So take a look at that too.
So let's believe the chosen settings are correct and the washer spins fine. Let's look further. Look for the basics first. If the dryer can't breath properly, it can't heat properly. I see you have an all electric dryer. You can pretty much rule out a bad thermostat as I have seen only a few failures in the last 20 years and if it's heating, even somewhat, they are working.
With that in mind it is most likely you have an issue with air flow restriction. I suggest cleaning the inner duct system first. Many times a large layer of lint will "roll off" of the filter and block the inside duct. If the problem persists, make sure the outer vent ducting is also completely clear of blockage. You will be surprised how much faster the unit will dry after these two things are cleaned.
As always, UNPLUG the appliance PRIOR to attempting any repairs AND be extremely careful of the extremely sharp stamp-cut edges of the machine as they are RAZOR SHARP!
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
SOURCE: My whirlpool gas dryer keeps coming up with E1
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
SOURCE: Have to run dryer twice to get clothes dried
also check the exhaust outside of the house, i had birds nest in mine
SOURCE: Whirlpool Duet Steam Dryer Beeping
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
