I do not know your exact model, but there are parts available on Ebay.com and here is a link to some of the bases available. https://www.ebay.co.uk/sch/items/?_nkw=jack+lalanne+power+juicer+base+parts&_sacat=&_ex_kw=&_mPrRngCbx=1&_udlo=&_udhi=&_sop=12&_fpos=&_fspt=1&_sadis=&LH_CAds=&clk_rvr_id=1429240681258&rmvSB=true
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Let me take a stab at it
There are two types of resistance... Static and dynamic. These resistance change depending on the position of the cone. Now im guessing the short bursts of bass are not small ones.
If the cones are forced further than allowed the resistance of the combinded drivers may drop below the rated impediance for the amp...causing the amp to into protection to keep itself from over driving itself (the less reistance a amp sees the more power it will produce, till it essential blows itself up)
A: make sure that speakers size and watts.B: Type of speakers is used for base. C: Make sure the current (Amps)of the battery and your amplifier. D: Check audio from source and decrease the level of base.
Thanks.
