Scrolling options for touchpad are not coming up in Mouse settings anywhere, how can I find it ??
SOURCE: Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
SOURCE: Scroll function on my Toshiba Satellite TouchPad isn't working
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s22
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
SOURCE: my touchpad it keeps scrolling, can I turn this off?
I had a similar problem with my Compaq EVO N610C Touchpad.
The latest driver form HP did not solve the problem.
I went to Synaptic's website and downloaed and installed their latest generic driver, no more problems!
Visit here: http://www.synaptics.com/support/drivers
Note, this may or may not work for you. Best to set a System Restore point before installing in case it does not work for you, worth a try.
Best of luck!
Tom
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
