Question about Worldwide 2000 Ford F350 Super Duty Pickup 6.8L Alternator - 130 Amps
How do I replace driver side door latch on a 2000 f350
How do I remove and replace the latch.
    Genius:
  • Worldwide Master
  • 2,548 Answers
They unscrew outer and come out from behind door trim,might need Allen keys.
Posted on Jul 25, 2014
Anonymous
SOURCE:
I have a 1996 Chevy Blazer that the door latch won't stay latched. Even going down the road
replace the broken latch --remove door panel to access latch and if repairable do it if worn and damaged remove screws on door jam remove latch and replace
Aug 16, 2018 | Cars & Trucks
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
Thought door was frozen shut on 96 grand am se so pulled it open and now it won't close latch not engaged and door lines up but won't stay latched shut....
The latch may already be latched like it is closed. You can take a screw driver and put it.. where the latch engages Slightly pry outward agianst the latch while pulling on the door handle. That should release the latch. If you continue to have the problem than the latch will have to be replaced because there is a plastic piece that may be worn out.You will have to remove the door panel to replace the latch. They sell a book on that car that will explain how to remove the door handle(at O'rielly).
Dec 09, 2010 | 2000 Pontiac Grand Am GT
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Change tke hood realase cable in hyundai elantra
Service and Repair Notes HOOD LATCH CABLE REPLACEMENT Remove the following items: Hood release handle. Radiator guard. Hood latch. Wheel guard. Using a clip remover, detach the clips from the body, then remove the hood latch cable (A) from the vehicle. NOTE: Take care not to bend the cable. Installation is the reverse of removal. NOTE: Make sure the hood latch cable is connected properly. Replace any damaged clips.
Jun 08, 2009 | 2005 Hyundai Elantra
2002 Explorer rear liftage latch replacement
Liftgate Latch Remote Control Removal and Installation
  1. Remove the liftgate trim panel. For additional information, refer to Section 501-05.
  1. Remove the watershield.
  1. Disconnect the actuator electrical connectors.
  1. Disconnect the liftgate window glass latch release cable.
    1. Release the cable conduit.
    1. Disconnect the cable.
  1. Disconnect the liftgate latch release cable.
    1. Remove the cable conduit.
  1. Release the exterior liftgate release handle actuating rod.
    1. Open the clip.
    1. Release the rod.
  1. Remove the bolts and the liftgate latch remote control.
  1. To install, reverse the removal procedure.
    • Transfer parts as necessary.
Jun 01, 2009 | 2002 Ford Explorer
2001 Ford Escape Rear Hatch won't unlock
The liftgate consists of the following components:
  • liftgate door lock actuator
  • liftgate lock cylinder (if equipped)
  • liftgate window glass
  • liftgate window latch/ajar switch
  • liftgate window glass release handle
  • liftgate latch remote control which consists of the following component:
    • liftgate release handle
  • liftgate latch, which consist of the following component:
    • liftgate latch door ajar switch
Liftgate Latch Actuator Removal and Installation
  1. Remove the liftgate latch remote control. For additional information, refer to Liftgate Latch Remote Control in this section.
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
  1. Disconnect the liftgate ajar switch electrical connector.
  1. Disconnect the liftgate latch actuating rod.
    1. Open the clip.
    1. Disconnect the actuating rod.
  1. Remove and discard the liftgate latch bolts.
  1. Remove the liftgate latch.
  1. NOTE: Make sure the liftgate latch release rod is not preloading the latch. It should be clipped in a relaxed state with no slack.
    NOTE: Position the liftgate latch release rod by pushing outboard to remove the slack.
  1. Remove the screws and the liftgate latch actuator
May 29, 2009 | 2001 Ford Escape
  2. Remove the watershield.
  3. Remove the bolts and the liftgate latch.
    • Discard the bolts.
  1. Disconnect the release cable.
    1. Disconnect the cable conduit.
gate latch.
Apr 10, 2009 | 2002 Ford Explorer
Worldwide 2000 Ford F350 Super Duty Pickup 6.8L Alternator - 130 Amps Logo
Top Worldwide Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
