It was winding up like the fan was getting loud on and off before this happened .It wont go in reverse but will go forward.
SOURCE: 02 Trailblazer will not go in reverse, but will go in drive
you probably have to reset the ecu!
SOURCE: wont go into reverse and doesnt go into 3rd unless i let off gas
It sounds like you broke the sun gear shell in the transmission. This is real common on 4L60E. The transmission will have to be disassembled to fix it. If this is what is wrong it will have no reverse and hold 1st till about 30 and then skip 2nd, right to 3rd. Then never shift in to 4th.
SOURCE: 2003 trailblazer makes winding noise when i accelerate.
common problem is idler pulley on drivers side of engine
