I need the wiring diagram for the AC compressor on a 2003 E320. The AC Compressor is not getting any power, I have checked the fuse and it is good, however I am at a loss to where to check next as I have not been able to find a wiring diagram for it.
SOURCE: 99 mercedes e320.check engine light on.po341
that appears to be a camshaft position sensor performance code. you can start by checking to see if the sensor is working properly, re-check and make sure that the harness is ok by checking the resistance through the harness if all looks well there make sure the computer has the latest software on it by having it scanned at your local dealer. also you can check the reluctor wheel on the camshaft for damage or debris in the way of the sensor.
hope this helps!
SOURCE: no power to the ac compressor
Have you checked the refrigerant level,If it is low,No power will be supplied to the compressor.
SOURCE: I need a diagram for a 2003 toyota corolla interior fuse box
Have you checked to se if there is freon in the system? If there is no freon, the compressor will NOT run.
SOURCE: NEED AC COMPRESSOR WIRING DIAGRAM
heres your wiring diagram for the ac system, not sure what engine you have but should still be the same.good luck,
SOURCE: AC Compressor not engaging on 2000 Chevy Impala.
When your R-134a runs too low it will NOT engage the compressor. You need to refill your a/c system before the clutch will engage, I also suggest finding the leak.
