Sounds like bad gas try to spray some 2+2 carb cleaner in the throttle body and see if it will start it should start for about a couple of seconds then shut off again
scan it.
plug (USA:"?) any scan tool
crank for 5 seconds,
stop relax key , not off
see scan DTC errors, i bet YES
no RPM scanning? yes, that means CKP is dead.
Replace spark plugs as they might have been worn and check the specific
gravity of the battery checked. The ignition coil also may be causing the
problem.
If the engine cranks but does not start, you will need to know if you are lacking fuel to the injectors, spark to the plugs, or compression to proceed.
Try putting the key in the driver door lock and turning from lock to unlock. That should dissable the factory alarm system. You may have to do it a few times before it works.
Starter may be locked up or bad. If Starter is Ok then it will be in the Ground from the starter. If Engine is Cranking and not turning over you are either not getting 1 or 2 things spark or fuel. No Fuel chances are, it is a bad fuel pump, If No spark it is a bad coil or distributor.
Found this solution and it worked for me on my 1996 Toyota Tacoma and fixed the problem you described...!!! Here it is
"I Hope You All Appreciate This FAST and EASY Inexpensive Repair That Even The Toyota Dealers Dont Seem To Know How To Fix !!! The Problem Is The Air filter temp sensor. Look On The Left Side Of the Air Filter Housing and Disconnect The Plug Thats Attached To The Spark Plug Like Plastic Sensor Mounted on The Side Of the Air Filter Housing, Now Go Start Your Truck !!! Your Truck Will Start And RUN Fine Now ! Replace The Sensor Approx $59 at Autozone... This Should Fix 90% Of Your Problems If your In the other 10% and it does not Fix it , Email Me and Ill See If I Can Help ! People Have Spent Hundreds and into The Thousand Dollar Area Trying to Resolve This Intermittant Problem At Inept Shops with Illiterate Mechanics ! If Your Happy With This Fix, BE Generouse ! I Do Accept Donations at Paypal Send to [email protected] Thank You JOE Mechaniac"
clogged injectors you need to put cleaner in the fuel to help get dirt and grit out of them some times (every 3 months). I am assuming you are saying it will turn over but not fire and run when cold?
This is a Toyota Tacoma 4x4 pick up 1999 year model
