SOURCE: how to open the jbl radial micro speaker set?
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
SOURCE: can you repair a broken ipod connector on the JBL On Time?
Yes it can
Fullers Electronics on 01728 746400
The board part number is: ZDTIMEWT0100G
SOURCE: i need to open a JBL onstage II speaker system to
you have to remove the 3 sticky pads in at the bottom of the speaker and there you will expose all the screws that need to be removed...there is also one where the batteries go
if you have any luck replacing the ipod dock let me know please
SOURCE: I-pod connector came off
this connector is available complete with pcb from jbl service center.But radial is very difficult to open.You need to open the mesh with a hair dryer,because it is heavely glued with hot glue on the borders.you will find screws inside.And also from the bottom & sides you have to remove this decorative strip.
it is very time consuming & headache.
i have myself replaced five of this docking sockets,it will take minimum of two to three hours to do this
