Air conditioner suddenly stopped working. Could it be a fuse?
SOURCE: 2002 VW Passat GLX AWD, stereo stopped working
HI,
Passats can be reset if the radio is pulled out and the fuse on the back is removed. Wait for 2 mins, reinsert the fuse and turn the radio on. If this doesn't work, please take it to the dealer for the unlocking of the code, for which he may charge you some fee.
Do let me know if it was helpful.
Regards
Kanu
SOURCE: my heat not workini but blow cold air where is
Has the car been changed coolant since it was bought? If it is time to change, let do a flush through a heater core. There are 2 coolant hoses going thru a fire wall. One for coolant in and one for coolant out. Heater only works if coolant is flowing through the heater core. Therefore, there are one or both following cases contributes to the problem: 1-If the valve control coolant flow gets stuck, then it always closes so there is no heat. 2-If the valve is working, but the heater core gets clogged up, then there is no heat.
SOURCE: Check engine light on. Trouble code P0599.
this code is for the theremostat heater control sensor that is under the intake. very labor intensive and should be handle by a quilified tech. the reason the code will not clear is because it is a hard fault and it is seeing it constantly or you do not have the proper scan tool with the correct software. it needs to be vag software and you can get one of these off ebay for under 50 dollars.
you can check the respected fuse for ecm circuit -j220 if that is okay it will need to be tested further.
let me know if you have any more question. good luck
SOURCE: 2001 passat fuse box diagram
It would be easier if you mention what device you're working with and I can tell you what number location it's fuse is at. Symbols are only there to confuse the hell out of you, although it's true purpose is to be recognized as a global standard. Now if you want to make it easier for yourself, buying a Bentley's repair manual is the only way to go. I hate to tell you that there are no free manuals you can down load, it cost money and someones time to upload a manual just to share it freely on the net.
SOURCE: Free 2003 Volkswagen Passat W8 4 Motion Fuse Box
Can someone help, I have an 03 passat w8 for about a yr
