I've changed the entire guts of the tank with universal products and even changed 3 different flappers. For some reason I am still losing water from my tank. What could cause this problem even afar replacing 3 brand new flappers.
The fill tube may have a crack in it. I am referring to the plastic tube where the water runs in from a small rubber tube connected to the fill valve to refill the bowl after you flush it also serves as an overflow tube in case the water level gets too high. a crack will allow water from the tank to run into the bowl bypassing the flapper. checks this and replace if necessary. hope this helps.
Bob
SOURCE: We have a crane toilet,
You're right it is a bad setup but Crane will not change their design. Most of the time it is from age and you have to replace the flapper system. I would go to the local hardware and buy a FluedMaster setup and change out the flush tube although that means taking the toilet apart.
