you may need to take it in to the camera place to get the internal batery for the clock replaced also you may need to up load the driver program for the camera
this sounds like the baterys are going down,, ie flat! you may also be using the wrong type of baterys in it, they eat normal one's!! only use high power type not ni-cads
also look at the programer is it set up in power saving mode??
Set setting to AUTO.
Charge batery or change batery.
Diract it to a lighted spot use external light.
set mode to power save and extend time to longer period.
Vitally
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
