When i turn the ignition switch on the left turn signal starts to flash. it will not turn off by pushing the left turn signal button. but if i press the right turn signal button it stops and the right signal flashes. push the right signal button again and it stops flashing. push the left turn signal button it does not flash.shut the bike off and turn on again the left turn signal starts flashing.
SOURCE: 01 Softail Deuce left turn signal comes on, will not go off @
I'm new to this site but actually has fielded a question about a Triumph motorcycle I'm worrking on!
I have an '03 Anniversary Deuce and I ran into (not the exact) but similar problem. My bike has the bars internally wired from the grips all the way through the top triple tree. Somehow over time the turn signal wire got shorted "internally". You might want to just unbolt the turn signal switch from the bars to see if the wire got pinched up high. If not...move the wires around to see if that helps. If it does...ultimately you should re-wire the connections. Just my experience...good luck!
SOURCE: why do my turn signals flash multiple times on my
You could have an alarm system built in...
SOURCE: left turn signal not working proper
Turn signals flashing is the confirmation of alarm system being on.I thought both sides flashed but if alarm is faulty guess that's messed up too. Try starting from stratch with alarm,disarm it[disconnect neg wire at battery]then reconnect wire and when that sets off alarm turn it off in normal way.That should get things back on track.Plus,try replacing the flasher unit,don't know why this works but I've heard of it.
SOURCE: Left turn indicator does not
If you will contact me directly, I can give you a complete troubleshooting guide for the turn signals. I cannot send it via this forum. E-mail me at [email protected] Don't forget to tell me what you need.
Good Luck
Steve
SOURCE: Battery is charged, but bike will not start. When
First, check the "Run/Stop" switch on the right handlebar switch housing. Make sure it's in the "Run" position. If it is, your starter relay may not be working. The relay is exactly like those on your car, a one inch plastic cube. Now, where it's located, I'm not sure. It could be under the seat or behind either of the two side covers on your bike. Once you find it, turn the switch on, hold on to the relay, and push the start button. You should feel the relay click. If it does click but the starter does not engage, you need to test the voltage coming out of the relay.
To test the output of the relay, look at the end of your starter from the right side of your bike. You'll see a five sided plate on the end of the starter solenoid. At the top of the plate, you'll see a single wire plugged into the starter. Unplug the wire and stick a test light probe in the connector on the end of the wire. Again, turn the switch on and press the start button. If the light lights up, your relay is good. If not, the relay is probably bad.
To do a final test on the starter, remove the five sided plate by removing the three small bolts that secure it. You'll see a plunger inside the solenoid. Make sure the bike's transmission is in neutral. Using a large screwdriver, push the plunger into the starter solenoid. The starter should engage and turn the engine over regardless of whether the switch is "on" or "off". Make certain that you push the plunger all the way in. If the starter does not turn, you starter is bad.
Good Luck
Steve
