Splendide 2000S Front Load Washer / Dryer Logo
A
Anonymous Posted on Jul 24, 2014
Splendide drum does not spin - Splendide 2000S Front Load Washer / Dryer
1helpful
Erratic Drum Operation
Can you clarify the problem, I don't fully understand what the actual problem is?
I have a Splendide 2000 s it will fill up with water and drain the drum does not turn and the control setting knob is going around
Drum motor brushes worn would be my first check. Does the drum spin freely by hand? If not then drum bearings are shot.
Splendide 2000 model# wd802 drains byt will not spin nor turn
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to used at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
