I have a Sylvania 19" model SSC 191 with combo which includes a VCR located at the bottom of the T.V.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: i lost the remote to my sylvania model; 6419TE 19
Have you tried the search fuction,some of the remotes will search for a code that works.
SOURCE: I need the Phillips universal remote control code
Give this a try http://www.universal-remote.net/philipsmagnavox.html
SOURCE: can I program a universal
I have an RCA Universal Remote Control for replacing 4 remotes and it lists 12 different codes for Sylvania TVs. As far as I know they don't usually list them by model number. There is also a site called NewRemoteControl.com where I found two generic remotes for your model and each of them was listed at around $18.00 American. I'm not sure what the cost of universal remotes in your area are but, if I were you I think I would also consider that.
SOURCE: HAVE A 20" SYLVANIA TV MODEL 6420FMG-REMOTE
Take it apart and wipe everything clean....I spilled soda on my remote and the same thing happened sometimes I'd push one button and I'd turn off the TV or go to the meny when I wanted to chabge the channel... A couple of screws and it will come right apart
SOURCE: I no longer have my
Press Channel Up/Down button to switch to TV mode and if that does not help then tv remote is required to change input source of tv/vcr combo.
Click HERE to download related user manual of tv.
and remote control is available in Remotes.com
Hope this will help.
Thanks.
