Flashing F10 and not heating up
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
