My whirlpool gold microwave starts, lights up, but won't heat anything (ice cubes stay frozen after 2 minutes). Is there a guide to replacing the door switch
SOURCE: Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You
can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find
helpful exploded view diagrams and order parts here.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: whirlpool gold microwave gt4175sps - problem: will
It sounds like there may be a diode or relay on the control that has failed. This could cause both symptoms you are explaining here. In either case the control board/keymembrane would need replaced. The cost of these would be about $173.00 for parts. Unfortunatly this repair would most likely cost more than the value of the product. Sorry for the bad news.
SOURCE: Need to replace a door handle on Whirlpool Gold
replace Whirlpool Gold microwave handle video
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
